| | | Forums66 Topics128,022 Posts1,055,386 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | What a job. both of the bleeder screws were broke off of the rear wheel cyls. used the PB plaster, heat, drilled out the 1st one and was finally able to get it out with a easy out, not so lucky on the second. easy out reamed the hole so had to go to a bigger one, still no luck finally had to use a drill bit that would meet up with the threads and then use a bottom tap to clean out the rest, took my time to make sure that i did not go all the way down into the seat, cleaned it up good looks like it will work just fine... just wanted to the share the experience | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Aren't these rusty old cars & trucks fun.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Dakota, you da man! Just shows "it can be done". | | | | | Joined: Dec 2007 Posts: 2 New Guy | | New Guy Joined: Dec 2007 Posts: 2 | Hello Dakota,
I live over the hill to the south of you in Green Valley on the south side of Hwy 44.. What is the truck you are working on? Those bleeders can be some of the biggest pia's on a vehicle. I haven't had much time to dig into this site, so I may be asking obvious questions. Cool to see a local!
Later---DAC
1970 GMC Jimmy K5 1972 GMC C2500 1955 GMC 100 2006 GMC Yukon Denali | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | Let me start by saying welcome to the bolt. always glad to see someone from the area join in. lot of info to be had I use the search a lot... the truck I'm working on right now is the 50 3600. for the boy. Again welcome and don't be afraid to ask someone will chim in for you
Alvin i did start to work on it again, you made me feel bad about sitting on my you know what... will try to do more.. as long as its not to cold... | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Mike, I'm sorry  .....but I promised LaVerne I'd see what I could do to get you out of the house  | | | | | Joined: Jan 2005 Posts: 394 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 394 | ggggggggggggggeeeeeeeeeeeeee thanks
and by the way tiny nothing like working on the old stuff | | | | | Joined: Dec 2007 Posts: 2 New Guy | | New Guy Joined: Dec 2007 Posts: 2 | Thanks for the welcome, Dakota. Got to look at some of your pics thru your profile link and I must say that you have some cool old trucks there. Even the F%&d is OK.
Later---DAC
1970 GMC Jimmy K5 1972 GMC C2500 1955 GMC 100 2006 GMC Yukon Denali | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Geeze Mike, If you would just buy my '53 you wouldn't have this problem.....OK, you probably would but you'd have another truck!
Bruce | | |
