| | | Forums66 Topics128,077 Posts1,056,013 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 3 New Guy | | New Guy Joined: Jul 2007 Posts: 3 | please help!!I have a 46 pu and I need some info on changing to rack & pinion steering or some solution for easier steering. I,m trying to keep it as close to stock as possible. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You might try greasing the steering and king pins. I was amazed at the difference it made in my '56.
You might have to remove the zerks and clean out dried grease before they'll take fresh. | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Cletis is right. The 46 steering box principle is still in use today. It is the recirculating ball type of steering box and with proper lubrication should work very easily for you. Just as an example, the early Mustangs use the same type of box. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Feb 2000 Posts: 5,213 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,213 | I had a '46 gear box on my '37 and thought it steered to easy. I went back to the older box. I know wish I had it back! Joe | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | A good set of properly inflated tires (I prefer radials) will help a lot too. | | | | | Joined: Oct 2007 Posts: 397 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 397 | I've got a '46 and the stock steering use to be sloppy due to lack of proper maintanance. I tightened up the sector gear to remove most of the steering wheel play and added grease to the steering box. After doing this good steering control plus ease of steering for this period/age of truck returned along with peace of mind. Having a truck wandering all over the road is a bit unsettling to say the least.
"Lucille" ..... Proud Member of the "Southern Stovebolts" David Wolff 1946 Chevy 1/2-ton In the Gallery | | |
