3 members (Gdads51, Flint48, 1 invisible), 187 guests, and 2 robots.
Topics128,088
Posts1,055,995
Members48,430
#357318 01/06/2008 10:39 PM
please help!!I have a 46 pu and I need some info on changing to rack & pinion steering or some solution for easier steering. I,m trying to keep it as close to stock as possible.
mums46 #357415 01/07/2008 2:39 AM
You might try greasing the steering and king pins. I was amazed at the difference it made in my '56.
You might have to remove the zerks and clean out dried grease before they'll take fresh.
Cletis #357425 01/07/2008 2:52 AM
Cletis is right. The 46 steering box principle is still in use today. It is the recirculating ball type of steering box and with proper lubrication should work very easily for you. Just as an example, the early Mustangs use the same type of box.
Joe smile
I had a '46 gear box on my '37 and thought it steered to easy. I went back to the older box. I know wish I had it back! Joe
Joe H #357747 01/07/2008 11:20 PM
A good set of properly inflated tires (I prefer radials) will help a lot too.
mums46 #357968 01/08/2008 2:48 PM
I've got a '46 and the stock steering use to be sloppy due to lack of proper maintanance. I tightened up the sector gear to remove most of the steering wheel play and added grease to the steering box. After doing this good steering control plus ease of steering for this period/age of truck returned along with peace of mind. Having a truck wandering all over the road is a bit unsettling to say the least.
"Lucille" ..... Proud Member of the "Southern Stovebolts"
David Wolff
1946 Chevy 1/2-ton
