0 members (),
115
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 66 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 66 | My 53 GMC doesn't have the correct wheel lug bolts in the front hubs. They are very long and fit loose in the hub. Does anyone know what part # I should be looking for ? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | '53 GMC What? The lug nut size is different on different models.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jul 2007 Posts: 66 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 66 | Sorry... Its a 53 GMC 9300. The PO used very long bolts and they don't seem to fit tight.He also had a spacer cut from what looks to be about 3/4" plate steel behind the rim. I want ot get rid of all that BS.
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I don't recall which US model the Canadian 9300 is the same as. Is this a 1/2-ton, 3/4-ton, bigger?
On a 1/2-ton the lugs are 7/16-20 I think.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I have had good luck at the auto parts store like NAPA finding both a listing for the bolts/studs by application, and then actually having them available too.
Grigg | | | | | Joined: Jan 2007 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 44 | hey wolf you could look at a farm machinery place like john deere or f##d newholland for the studs and lug nuts they deal in the really oddball stuff all the time sincerly joe
| | | | | Joined: Jul 2007 Posts: 66 'Bolter | | 'Bolter Joined: Jul 2007 Posts: 66 | Thanks
The 9300 is the same as a 3100. It's a 1/2 ton. I found a listing for them in the LMC book, $2.95 each | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I'd check your local parts store. You can probably get them across the counter for far less money. You'll just need to take the hub apart so you can determine the correct length to request.
