1 members (RLB),
119
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,110 Posts1,056,241 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 12 New Guy | | New Guy Joined: Oct 2007 Posts: 12 | My '54 has the old mechanical/vacuum wiper motor and I would like to keep it if possible.
I've taken it out, cleaned and lubed it, see no excessive wear, but it still doesn't work very well. The vacuum line looks decent, but I'm going to replace it anyway.
The problem I have is it is very slow, stops frequently and hangs whenever I stomp on the gas. Can anyone tell me if that is normal? I see they sell an electrical replacement, but again would like to keep it original if I can. | | | | | Joined: Feb 2000 Posts: 5,216 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,216 | It will all ways stop when you step on the throttle, your vacuum drops off when the throttle blade is opened, this is why they went to a electric wiper system. Add some oil to the wiper motor, the old leather seals tend to dry out over time. Use a leather oil, I heard motor type oils will degrade leather over time. If there is a question about vacuum, install a gauge at the wiper motor to monitor how much vacuum there is. Mine used to run like yours, slow and unsteady, I had them rebuilt and now they all most throw the wiper off the arm they are so fast. My engine idles with 19.5" of vacuum. They are easy to rebuild, but getting parts is tough. Joe | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I have had these motor professionally rebuilt and as Joe say's they tend to throw the old style wiper blades off the arm. Check out www.wiperman.com I need to go to a more modern arm and blade to cure this problem. If you guys have a source for a better than stock arm/blade I'd like to know. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I use Rowlands parts in Wa. You pack it up & send it with a check & they send it back working great. You can,t turn it up all the way or like Joe says they go too fast. There phone number is 509-829-5026. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
