0 members (), 75 guests, and 3 robots.
Topics128,211
Posts1,057,475
Members48,473
Apprentice
Apprentice
Ive got a 51 6400 with a dump bed. I want to install a dual master with the booster in front of it. i can
make a bracket and hook up the pedal but i think im gonna have clearance problems with the pto on the tranny so what are some other options. dual m/c with
2 hydrovacs. somebody help me here. thanks
Apprentice
Apprentice
Anybody have any suggestions??? eek
May not work, but I was prowling the pick-and-pull yesterday and saw a Dodge 3/4 or 1 ton van with a hydraulic booster instead of the vacuum servo. It wasn't much bigger than the MC. It needs a power steering pump to supply pressure. Very compact set-up, it was across the firewall, but I bet it would mount well under the floor.
I've seen hydraulic power brakes on Chevy diesel pickups too. I'd bet they were used on a lot of GM diesel vehicles.
If you are also running power steering the same pump can provide power to both.
I think my gas powered motorhome has the same kind of setup, except it was designed to handle a 12,000 pound load. Its too dark and wet out there to go look right now.
