| | | Forums66 Topics128,196 Posts1,057,395 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35530 02/12/2005 2:02 AM | Joined: Nov 2004 Posts: 29 Apprentice | | Apprentice Joined: Nov 2004 Posts: 29 | Ive got a 51 6400 with a dump bed. I want to install a dual master with the booster in front of it. i can make a bracket and hook up the pedal but i think im gonna have clearance problems with the pto on the tranny so what are some other options. dual m/c with 2 hydrovacs. somebody help me here. thanks | | |
#35531 02/12/2005 4:51 PM | Joined: Nov 2004 Posts: 29 Apprentice | | Apprentice Joined: Nov 2004 Posts: 29 | Anybody have any suggestions???  | | |
#35533 02/13/2005 12:50 AM | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | May not work, but I was prowling the pick-and-pull yesterday and saw a Dodge 3/4 or 1 ton van with a hydraulic booster instead of the vacuum servo. It wasn't much bigger than the MC. It needs a power steering pump to supply pressure. Very compact set-up, it was across the firewall, but I bet it would mount well under the floor.
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
#35534 02/13/2005 5:01 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I've seen hydraulic power brakes on Chevy diesel pickups too. I'd bet they were used on a lot of GM diesel vehicles.
If you are also running power steering the same pump can provide power to both.
I think my gas powered motorhome has the same kind of setup, except it was designed to handle a 12,000 pound load. Its too dark and wet out there to go look right now.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
