7 members (Shaffer's1950, 54farmtruck, Southerntruck, Lightholder's Dad, Pre '68 Dave, Donf, rfs56trk), 126 guests, and 1 robot.
Topics128,189
Posts1,057,337
Members48,469
Would any of the cars from that hydromatic era be poss. match for the turn signal?
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
60's Poncho's, Olds and Cadillacs all used Hydromatics however I don't think the turn signal has anything to do with that. Good luck.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
???HYDRA MATIC???
Riding in the Passing Lane
The original Hydramatic started in the early 40,s & was used extensively in 46 up O.P. & cads. In 56 some started going to different versions. I take it you want to use a turn switch from one on a Stovebolt. Seems like it would work.
1972 Chevy c10 Cheyenne Super
The Hydamatic was first used in Oldsmobiles, starting in 1938, I think; Pontiac and Cadillac started using them later, but I don't know with any certainty when they started. Buick had the Dynaflow, starting in 1948 or so, but I don't know that for sure, either. Chevrolet began the Powerglide automatic in 1950, and Pontiac used the two-speed Powerglide (1953 and later transmission) for a time in 1953-1954 because of a shortage of Hydramatics. I don't know the number of Pontiacs that used the PG transmission- I never saw one in service, but some after-market transmission gasket sets were listed as applying to 1953-54 Pontiacs with Powerglide transmission. I don't think any of this applies to your original question, though.
If anyone is interested in the Pontiac/Powerglide useage, I may be able to find something more on that.
Harvester
My 1955 Pontiac has a dual range hydramatic, the use of power glides was because of a fire at the plant in 1954. Pontiac used differant versions of the hydramatic up until 1964? with the last series using a PARK position. GMC trucks from 1955 until 1958(?) used Pontiac V-8's and you could get a hyrdamatic transmission.
In the 1960's Pontiac used a 2 speed transmission it was not a powerglide but a version called a super turbine.
John Gott
1942 G5106 1.5-ton Chevy cargo dump Gallery page
Old Dominion Stovebolt Society
T/Sgt. Gott (28 years of service with the USPP)
1940 Chevy G506 4112 cargo dump
1942 Diamond T G509 969A 4 ton wrecker
1942 Ward LaFrance G116 series 2 10 ton wrecker
1944 Ward LaFrance G116 series 5 10 ton wrecker
1931 Ford AA with a WEAVER crane
1944 Sterling HC 165 tractor
1944 Autocar U7144T w/ 10 ton trailer
