1 members (UtahYork),
128
Mod | | | Forums66 Topics128,186 Posts1,057,318 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Would any of the cars from that hydromatic era be poss. match for the turn signal? | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | 60's Poncho's, Olds and Cadillacs all used Hydromatics however I don't think the turn signal has anything to do with that. Good luck. | | | | | Joined: Nov 2006 Posts: 60 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 60 | | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The original Hydramatic started in the early 40,s & was used extensively in 46 up O.P. & cads. In 56 some started going to different versions. I take it you want to use a turn switch from one on a Stovebolt. Seems like it would work.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | The Hydamatic was first used in Oldsmobiles, starting in 1938, I think; Pontiac and Cadillac started using them later, but I don't know with any certainty when they started. Buick had the Dynaflow, starting in 1948 or so, but I don't know that for sure, either. Chevrolet began the Powerglide automatic in 1950, and Pontiac used the two-speed Powerglide (1953 and later transmission) for a time in 1953-1954 because of a shortage of Hydramatics. I don't know the number of Pontiacs that used the PG transmission- I never saw one in service, but some after-market transmission gasket sets were listed as applying to 1953-54 Pontiacs with Powerglide transmission. I don't think any of this applies to your original question, though.
If anyone is interested in the Pontiac/Powerglide useage, I may be able to find something more on that.
Harvester | | | | | Joined: Aug 2004 Posts: 242 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 242 | My 1955 Pontiac has a dual range hydramatic, the use of power glides was because of a fire at the plant in 1954. Pontiac used differant versions of the hydramatic up until 1964? with the last series using a PARK position. GMC trucks from 1955 until 1958(?) used Pontiac V-8's and you could get a hyrdamatic transmission. In the 1960's Pontiac used a 2 speed transmission it was not a powerglide but a version called a super turbine.
John Gott 1942 G5106 1.5-ton Chevy cargo dump Gallery pageOld Dominion Stovebolt Society T/Sgt. Gott (28 years of service with the USPP) 1940 Chevy G506 4112 cargo dump 1942 Diamond T G509 969A 4 ton wrecker 1942 Ward LaFrance G116 series 2 10 ton wrecker 1944 Ward LaFrance G116 series 5 10 ton wrecker 1931 Ford AA with a WEAVER crane 1944 Sterling HC 165 tractor 1944 Autocar U7144T w/ 10 ton trailer
