Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#354443 12/31/2007 2:47 AM
Apprentice
Apprentice
Running a old rochester carb on my 41 216. Been haveing problems with it, I have a rebuilt rochester off a 261 figured I would swap it out to the 216, Boy was I wrong! It won't fit on the 216, the base and bolt holes are close to 1/2 inch wider than the carb off the 216. Both carbs are identical except the base! I thought all the carbs, 216-261 would interchange? Can anyone fill me in on this?
Also any opinions on the rochester and carter carbs?
Steves41,
I'm not 100% on this, but I believe the 216 carburetor had a 2- 11/16" bolt spacing and the 235 had a 2-15/16". These have SAE numbers associated with them although I don't know what they are.
I thought the 261 used the same bolt spacing as the 235! The difference between the two bolt spacings is only 1/4" isn't it.
Stuart
Apprentice
Apprentice
Stuart
Yes closer to the 1/4 inch. but also the whole base is bigger.
I think what I should do is just put the 261 in the truck and quite nursing the old 216.
Stuart is correct that the 54-62 235 Rochester carb has the same spacing as the 54-62 261 Rochester carb.
The earlier 235 and all 216 carb bases are the same and have the closer bolt spacing.
Won't the base of the 216 fit the top of the later model carb. I thought someone had done that.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
The 261 carb should have different sided orifaces in the power enrichment circuit and probably different hole locations in the throttle body than the 216 carb. It may also have a larger venturi bore. Its more than just the jet that changes between the 235 and 261.
Paint & Body Shop moderator
Is there a differance between the 235 and 261 carbs?? I know they wil interchange but I recently purchased a GM NOS in the box carb for a 261 marked as such. I can't see any differances, possibly internal? ohwell
My Trucks
Stuff I Collect
V
V Offline
I have a 261 engine and I understand the bolt pattern is the same but there is a fuel/jet difference between the 261 and 235 carbs. But if you have a 261 engine with a 235 head on it, which carb should be used?
+1 on Stuart's dimensions. The 261 carb definetly has a bigger throttle bore than a 235 one but they seem to be listed as the same for replacement purposes.
You Tube
I guess I don't need to worry as my NOS 261 carb will be going on my 261. I hope the old carb on the 261 is original (I'm sure it is) but how can I tell? I've never looked, are there part numbers on them? blush
Bruce
My Trucks
Stuff I Collect
