2 members (Otto Skorzeny, 1955 1 Series), 116 guests, and 0 robots.
Topics128,115
Posts1,056,294
Members48,439
#354571 12/31/2007 10:22 AM
Apprentice
Apprentice
I have a 1953 Chev 3100 PU with a 56 235 engine. I plan to rewire the truck soon, currently I have a older Altenetor with an exteral regulator that I would like to replace at the same time. I see from other posts that the Delco 12si altenator is one people have had good luck with. When shopping for new wiring harneses it seems that you can only get a 12 volt harness for altenatores with internal regualators. Is the Delco 12si the altenator I should use and will it mount to my bracket?
kanskybrian,
I think the mounting for those alternators is pretty universal, it should fit right on your existing bracket.
Did you transpose a word in your post...internal/external in regards to the available wiring harness.
If a wiring harness is available that is constructed for a internally regulated alternator, you are all set. Isn't this the style of the 12si!
Stuart
The Delco 12SI was the replacement for the Delco 10SI. The 12SI was typically a higher amp. 78-94 amps was what they came in. The 12SI and 10SI will both bolt up in place of the 10DN that you are currently running. Only difference was that on some of the 12SI alternators they had a slick mounting hole on the adjusting ear and internal parts of course. If your going to upgrade to an internally regulated alternator I would suggest going with a self exciting one wire Delco. Its a lot cleaner, neater wiring set up. I can help you out with what you need but you will need to Private message me on this site for more info.
Ken
