2 members (Southerntruck, Hush),
150
Mod | | | Forums66 Topics128,114 Posts1,056,287 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 25 Apprentice | | Apprentice Joined: May 2007 Posts: 25 | I have a 1953 Chev 3100 PU with a 56 235 engine. I plan to rewire the truck soon, currently I have a older Altenetor with an exteral regulator that I would like to replace at the same time. I see from other posts that the Delco 12si altenator is one people have had good luck with. When shopping for new wiring harneses it seems that you can only get a 12 volt harness for altenatores with internal regualators. Is the Delco 12si the altenator I should use and will it mount to my bracket? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | kanskybrian,
I think the mounting for those alternators is pretty universal, it should fit right on your existing bracket.
Did you transpose a word in your post...internal/external in regards to the available wiring harness.
If a wiring harness is available that is constructed for a internally regulated alternator, you are all set. Isn't this the style of the 12si!
Stuart | | | | | Joined: Nov 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 190 | The Delco 12SI was the replacement for the Delco 10SI. The 12SI was typically a higher amp. 78-94 amps was what they came in. The 12SI and 10SI will both bolt up in place of the 10DN that you are currently running. Only difference was that on some of the 12SI alternators they had a slick mounting hole on the adjusting ear and internal parts of course. If your going to upgrade to an internally regulated alternator I would suggest going with a self exciting one wire Delco. Its a lot cleaner, neater wiring set up. I can help you out with what you need but you will need to Private message me on this site for more info. Thanks Ken
