| | | Forums66 Topics128,203 Posts1,057,412 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35373 03/31/2003 5:25 AM | Joined: Jun 2001 Posts: 793 Bondo Artiste | | Bondo Artiste Joined: Jun 2001 Posts: 793 | Hello everyone. After a long hard winter my old truck is ready to roll and get tuned up. I noticed when I was driving late Friday night when the brakes were applied firmly the truck drifted to the right and I had to correct it by turning the steering wheel left to keep straight. I am not sure what the cause might be. I put the truck up on my lift and all looks good, no leaks and the fluid is clean. Any advice would be great and thanks in advance for your help.
Phillip 1951 GMC 9300 Canadian built 1/2 ton Centreville Va
~ Phillip 1949 GMC Suburban - 10 year project 1952 Pontiac Chieftain Convertible straight 8 hydramatic 1945 GMC half ton truck - Driver- Sold 9-15-25 1946 Chevy COE - SOLD 1-5-26 BUH BYE CHEVY! 1959 GMC Half ton long bed NAPCO | | |
#35374 03/31/2003 5:33 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | I'd suspect brake adjustment right off, but it could also be a bit of condensation [w/ maybe a wee bit of fluid film] has "glazed" things - I'd "ride" the brakes a bit a few times to see if they'll clean up w/ the heat, then if adjustment don't fix it, pull the drums and take a look - if there's no real leak, maybe a little scuff w/ sandpaper would fix it up
Bill | | |
#35375 03/31/2003 9:16 AM | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | I had the same problem, turned out to be a stuck rear shoe had glazed and was providing zero braking power. Pull the drums and see if everything moves like it should, check for glazing and leaks. Readjustment is mandatory, even if replacement is not required. Scuff up the shoes a bit even if they don't look shiny. | | |
#35376 03/31/2003 9:06 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | You could have a rubber flex line with a weak spot. I've had a few cars with pulls that were fixed with new flex lines. Now I use braided stainless lines on everything. They never wear out, and have incredible pedal feel. | | |
#35377 04/03/2003 3:05 PM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | Three things to check, oil contamination, brake fluid/ wheel bearing grease, Incorrect brake shoe adjustments, and the third if you have an IFS supension check the right hand side of the truck for worn parts (inner a arm bushings, tie rod idler arm etc), if it a solid front axle check the spring eye bushings | | |
#35378 04/08/2003 6:36 PM | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | One other thing to check is the air preasure in you front tires make sure that they are booth the same.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
