4 members (Maybellene, klhansen, 2 invisible), 87 guests, and 3 robots.
Topics128,211
Posts1,057,468
Members48,471
Bondo Artiste
Bondo Artiste
Hello everyone. After a long hard winter my old truck is ready to roll and get tuned up. I noticed when I was driving late Friday night when the brakes were applied firmly the truck drifted to the right and I had to correct it by turning the steering wheel left to keep straight. I am not sure what the cause might be. I put the truck up on my lift and all looks good, no leaks and the fluid is clean. Any advice would be great and thanks in advance for your help.
Phillip
1951 GMC 9300 Canadian built 1/2 ton
Centreville Va
~ Phillip
I'd suspect brake adjustment right off, but it could also be a bit of condensation [w/ maybe a wee bit of fluid film] has "glazed" things - I'd "ride" the brakes a bit a few times to see if they'll clean up w/ the heat, then if adjustment don't fix it, pull the drums and take a look - if there's no real leak, maybe a little scuff w/ sandpaper would fix it up
I had the same problem, turned out to be a stuck rear shoe had glazed and was providing zero braking power. Pull the drums and see if everything moves like it should, check for glazing and leaks. Readjustment is mandatory, even if replacement is not required. Scuff up the shoes a bit even if they don't look shiny.
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
You could have a rubber flex line with a weak spot. I've had a few cars with pulls that were fixed with new flex lines. Now I use braided stainless lines on everything. They never wear out, and have incredible pedal feel.
1954 GMC De Luxe COE
Three things to check, oil contamination, brake fluid/ wheel bearing grease, Incorrect brake shoe adjustments, and the third if you have an IFS supension check the right hand side of the truck for worn parts (inner a arm bushings, tie rod idler arm etc), if it a solid front axle check the spring eye bushings
One other thing to check is the air preasure in you front tires make sure that they are booth the same.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
