11 members (52Carl, carbking, Gdads51, Bill Hanlon, 1955 1 Series, 2-Ton, Robert Crandall, fonz8261, greenie-reddy, 2 invisible), 116 guests, and 1 robot.
Topics128,124
Posts1,056,347
Members48,441
#35366 07/15/2003 3:05 PM
Apprentice
Apprentice
I have a '49 1/2-ton with a 3-speed transmission. It leaks like crazy when either in reverse or idle. Otherwise, no leak. You can see the streak start where I put it in idle down the driveway or when backing into the garage. Someome mentioned the idler gear, which makes some sense, but I am not sure why that would cause a leak. I see the "stream" coming out of the hole in the cover over the flywheel. Honestly not even sure whether it is leaking gear oil from the tranny or engine oil. I did have the rear main seal replaced a while back.
Any ideas?
Greg - 49 1/2 ton
Oly Offline
I have a hunch that it is going to be the rear main seal that is your problem. Doesn't make much sense to be the tranny. If it is your rear main seal try this tech tip- tech tip Be sure to get the wick type seal with asbestos in it. Seals a lot better. Do it yourself- it is really easy to do. Then you know it is done correctly.
Oly in Oregon
Rest in Peace
1945 GMC COE Victory Truck
1953 Willys CJ3B
1955 Chevy 1st series 3/4-ton
1958 WIFE Last series
Never say "Whoa" in a mud hole
Is it possable that you have too much oil in the truck???
Apprentice
Apprentice
Well... too much oil did cross my mind, because in spite of the leak, it is still showing full each time I check it. Would this kind of leak be a symptom of too much oil, though?
Greg - 49 1/2 ton
How about a smell test ? I also am investigating a possible leaky tranny issue. To me tranny oil smells much different than engine oil. What I've seen on the ground smells just like tranny oil.
Craig
An overfilled tranny will barf oil.
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
Have you checked the oil level in the tranny?
there is suppose to be either a shield/slinger or a felt type seal in the front nose-cone of the tranny. Some have a helical cut groove in the tranny input shaft which when it is turning will sort of force the oil back toward the inside of the tranny.
Tranny gear oil will be a lot thicker and smell pretty bad as compared to the engine oil. If you are not losing any engine oil, I would definitely inspect the tranny.
