| | | Forums66 Topics128,162 Posts1,056,933 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 2 New Guy | | New Guy Joined: Jul 2007 Posts: 2 | building a 1957 chevy 3100, installing a 468ci bbc with enderlin mechanical injection set up and headers. plan on installing a power brake booster/duel master cylinder under the cab,,,, will this cause a heating issue, like boiling the brake fluid after a long drive,,, what do u all think, rather not put it on the dash for appearence purposes, thanks | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | My fifty-six is a 6100 big bolt but I believe it all fits pretty much the same. My headers are long tubes that are really designed for 67 to 72 big block pick-up wit a 4spd. My steering box has been moved or the headers I chose would not fit anyway they don't reach the as fare as the master cylinder and booster. Here are some pictures of what I have so far. The brake unit I am using http://rides.webshots.com/photo/2701798080096773078qEsBliThe 496 stroker being mocked in place and the new steering box http://rides.webshots.com/photo/2116948240096773078UOFriQOne from the top front http://rides.webshots.com/photo/2008997720096773078MfaEcwOk I don't have one that show the header brake unit clearance but my headers terminate at the bell housing cross member. There are many pictures in my webshots of this project feel free to cruse through them hope they are of some help to you. | | | | | Joined: Apr 2005 Posts: 2,101 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,101 | It gets fairly tight in that location depending on the transmission and the size of the pipes. You may wish to consider a heat shield or insulation on the pipe near the brake unit. Fred
| | | | | Joined: Apr 2007 Posts: 147 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 147 | I have been running a big block in my 55 since 1970, I don't have a power brake setup but have never had a problem with the manual brakes in all that time. The truck carried an 8 ft camper in the hot Texas summers for 3 yrs with no trouble. I am using the Chevelle headers, and have modified the pipes on the 2 back cyls to clear the stock steering box. With the truck headers, which I have also used, I didn't want to make any mods to the frame because the truck is a Cameo and not very common. You would have even more separation between the booster and the pipes because the truck pipes drop lower than the car headers. I am planning to put my power brake system in the underfloor location when I change back to a 2wd from its present 4wd setup. Bob
55 Cameo 396 TH 400 with overdrive 65 Caliente conv 67 BB Caliente conv 67 Mercury 1 Ton 76 GMC 3/4 ton 454ci 84 Buick Turbo Regal
| | | | | Joined: Feb 2004 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2004 Posts: 41 | hey there big block cameo do you have any pics you could send me showing the headers and engine in the truck? i plan on building a 496 stroker for my 1956 3100.what year chevelle headers did you use?thanks | | | | | Joined: Jul 2005 Posts: 946 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 946 | Hey BigBlockCameo what did you do with the 4wd set up? Was it the original factory NAPCO (NAPCO is stamped on the front axle tube)?
| | | | | Joined: Apr 2007 Posts: 147 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 147 | Sorry Guys, I've been away from the site for medical reasons and didn't see the questions. I have been using these headers so long that I can't be positive about the year. I am reasonably certain that they are from a 67, but because I have the stock steering box, I had to cut the back two pipes on the left side and weld them in a little tighter to clear the steering box. The modification shouldn't make any difference as to whether you are using the front or the more modern side engine mounts. I have used both truck and the car headers on the truck because I put the engine in in 1970, and have worn out a few sets. The headers have tons of room, you can slip both sides in without moving or disconnecting anything. ( my engine has the front mounts) It isn't possible to get you a good picture right now because I am in the middle of trying to get a garage built and have some serious health issues. I'll get a pm to you when I can move the truck. When are you starting the swap? Bob
| | | | | Joined: Apr 2007 Posts: 147 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 147 | I used the front and rear diffs and 203 transfer case from a 1976 Blazer. It is a long time ago, but the swap just took time to piddle around with little stuff. I used a different pitman arm, but I can't remember what truck I removed it from. The biggest part of the job was welding the spring pads and narrowing the distance on the diffs slightly to match the 55 springs on the stock frame. I also had to find a pair of 4" lowering blocks to raise the rear of the truck to be level with the front, because the diffs mount below the springs. I have a Corvette power steering unit ready to install when I can get back to working on the truck I am going to reconvert it back to a 2wd, but I have to get this garage finished and take care of some other critical priorities first. Bob
| | | | | Joined: Feb 2004 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2004 Posts: 41 | hi bob gonna do swap sometime this spring whenever you get a chance to get a couple pics will be great. | | | | | Joined: Apr 2007 Posts: 147 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 147 | OK, as soon as I can get a reasonably bright day. The truck is outside and its rainy.
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | From my experience,that should not create a heat problem.However if it does a simple heat shield would take care of it. | | | | | Joined: Oct 2006 Posts: 17 New Guy | | New Guy Joined: Oct 2006 Posts: 17 | Big Block, I hope things are getting better for you. Take care of your health! Wizard 50. | | | | | Joined: Apr 2007 Posts: 147 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 147 | Thanks wizard50, I am a 20 year cancer survivor, but I am not in remission. I am in a constant battle with the side effects of the drugs used to control my condition and the problems caused by the disease itself. I am going through a whole new round of tests to see if there is anything the doctors can do to improve things a little. I am not planning on quitting anytime soon. Best wishes for the new year.
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Bob, I would respectfully like to be copied on those pictures too. I just installed an L98 350 in my truck and clearance issues with the stock steering box is ridiculous. I'm ready to break down and buy the Sanderson iron header/manifolds (QP1000).
I won't be working on finishing my truck until at least springtime either, having just had open heart surgery. So I sympathize with your health issues and wish you well. Tony
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | | | | Joined: Apr 2007 Posts: 147 Shop Shark | | Shop Shark Joined: Apr 2007 Posts: 147 | Tony, I am marking the thread and will get the pictures for you as well. Happy new year. Bob
