3 members (jay d, 2 invisible),
54
Mod | | | Forums66 Topics128,009 Posts1,055,292 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 58 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 58 | Found the casting number for the engine which is 3764476 which makes it a 58-62 235. The other ID on the plate I found is F6I2J. The only "F" I'm seeing here http://www.americanclassic.com/paint.htm?p1=engines is 8 cyl. What am I reading wrong? The truck is a 59 3200 Fleetside. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you're not looking at the right thing, first letter is plant [F is for Flint], last is the application - J is the relevent letter, and it's listed as 1/2T 6cyl 145hp manual trans - the series 1100 and 1200 aren't trucks
Bill | | | | | Joined: Dec 2007 Posts: 58 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 58 | That makes much more sense. Thanks. The middle are date codes then from what I gather. | | |
