0 members (), 61 guests, and 4 robots.
Topics128,024
Posts1,055,395
Members48,422
#353297 12/27/2007 10:40 PM
Found the casting number for the engine which is 3764476 which makes it a 58-62 235. The other ID on the plate I found is F6I2J. The only "F" I'm seeing here http://www.americanclassic.com/paint.htm?p1=engines
is 8 cyl. What am I reading wrong?
The truck is a 59 3200 Fleetside.
1959 Apache 3200
Apache3200 #353311 12/27/2007 11:10 PM
you're not looking at the right thing, first letter is plant [F is for Flint], last is the application - J is the relevent letter, and it's listed as 1/2T 6cyl 145hp manual trans - the series 1100 and 1200 aren't trucks
Flxible #353320 12/27/2007 11:44 PM
That makes much more sense. Thanks. The middle are date codes then from what I gather.
1959 Apache 3200
