6 members (52Carl, Stovebolt48, Southerntruck, Wayne67vert, baldeagle, cmayna), 156 guests, and 1 robot.
Topics128,195
Posts1,057,380
Members48,471
I don't have enough experience! Does a 1929-30 Chevrolet 1-1/2 ton truck have an open drive line or is it enclosed? If this model has an enclosed drive line, will a late 40's pick-up truck 4 speed fit to the drive shaft housing? Another question, what is the wheel track of a 1937-40 1-1/2 ton with dual rear wheels? How does that measurement compare to the 1929 Chevrolet with single disk wheels? Please share your experience if you can.
Alan
smile Alan
1947 (early) GMC EC-302 Dump Truck
Jimmy
More pix in Photobucket
Enclosed drive shaft. 4 speed will not fit. The 37 distance between center line of spring from side to side is 42". Tread width on the 37 tire center line is 58 & 17/32 in. and the dual wheel outer is 73 & 3/8 in. If you want to do this just to install dual wheels if you use a 1930 trans. and rear end that was the first year Chevrolet offered dual wheels and all the parts will fit a 1929.
34 & 35 trucks are the greatest
Thanks for your reply. I am guessing that the 1930 4 speed and rear end with duals, are of the open drive shaft version? Does anyone have the remains of a 1930 1-1/2 ton laying around?
Thanks, Alan
smile Alan
Jimmy
Al, That is still a enclosed driveline. I have a '31 tow truck with duals and it is closed.
Cleon
1949 Chevy 6400
1931 Chevy Firetruck
All the 1.5 tons were closed drive shaft from 1929 pass the 1939's
