7 members (55shaker, KEVINSKI, klhansen, Rusted Nut, Phak1, JoergK., 1 invisible),
101
0
Mod | | | Forums66 Topics128,195 Posts1,057,376 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 171 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 171 | I don't have enough experience! Does a 1929-30 Chevrolet 1-1/2 ton truck have an open drive line or is it enclosed? If this model has an enclosed drive line, will a late 40's pick-up truck 4 speed fit to the drive shaft housing? Another question, what is the wheel track of a 1937-40 1-1/2 ton with dual rear wheels? How does that measurement compare to the 1929 Chevrolet with single disk wheels? Please share your experience if you can. Thanks, Alan | | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | Enclosed drive shaft. 4 speed will not fit. The 37 distance between center line of spring from side to side is 42". Tread width on the 37 tire center line is 58 & 17/32 in. and the dual wheel outer is 73 & 3/8 in. If you want to do this just to install dual wheels if you use a 1930 trans. and rear end that was the first year Chevrolet offered dual wheels and all the parts will fit a 1929.
34 & 35 trucks are the greatest
| | | | | Joined: Dec 2007 Posts: 171 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 171 | Thanks for your reply. I am guessing that the 1930 4 speed and rear end with duals, are of the open drive shaft version? Does anyone have the remains of a 1930 1-1/2 ton laying around? Thanks, Alan | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | Al, That is still a enclosed driveline. I have a '31 tow truck with duals and it is closed. Cleon | | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | All the 1.5 tons were closed drive shaft from 1929 pass the 1939's
