8 members (KEVINSKI, mick53, 55shaker, Peggy M, Gdads51, Hanks custodian, MickeyP, 1 invisible), 148 guests, and 5 robots.
Topics128,089
Posts1,056,137
Members48,435
#352891 12/26/2007 10:36 PM
Hey garage gooroos, Got a good one here!
I am planning to take out an original Chevy 216 (1937) from a
Chevy master car with the 3 speed in the floor and I want to install a Chevy 235 (1955?)motor to the original 1937 3 speed.Can this be done? The numbers from my 235 dates it from a 1955 to 1958 block and its mounted up to the floor shifter from my 1948 pickup tork tube tranny. I have talked my Dad into putting this into his car as long as its not to much trouble. The 'ol 216 blowed a head gasket so instead of fixing that, were gonna replace it with a newer 6 banger.
Any help would be appreciated!!!!!
bowtiesr4me #352910 12/26/2007 11:18 PM
Actually, it's not too difficult at all. You'll need to swap the bellhousing, starter, and front plate to the 235, and source a '41-'54 flywheel to make it work. There's also a few small things, like an adapter fitting for the temp sender, and some minor alterations to the throttle linkage and exhaust pipe to make it fit perfectly.
Bill Burmeister
LONGBOX55 #352950 12/27/2007 12:59 AM
The way it sounds to me is ... between the original 216 and the 235 along with my 1948 bell housing and starter I should be ok. They both (my 48 pickup and my Dads 37)have floor starters, so we should have enough parts to make it work.
Thanx for your help! LONGBOX55
