0 members (),
107
Mod | | | Forums66 Topics128,275 Posts1,058,572 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 14 Apprentice | | Apprentice Joined: Oct 2007 Posts: 14 | Hey Guys! I have a 1951 3600 I am rebuilding. Budget is a major issue with me as it is with most people. My wing glasses are shot in every way possible and I am missing the frame from around the glass in one of the main windows as well as the inside window garnish from both doors. I was wondering if it would be cheaper if I just replaced the wings and the main glass with the one piece 1950 or earlier glass. I think the door itself is the same but is the door hardware the same? I hate to drop the big bucks on new corner glasses when authenticity isn't a concern since the truck is going on an S-10 frame. Any ideas and or suggestions are welcome and very much appreciated! Thanks to all and Merry Christmas
MarcB
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Given that you have the turn-down type door handles I'd just swap doors from an earlier truck. No modifications required.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Mar 2002 Posts: 9,117 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,117 | There are differences inside the door and the winder is different. Some people have down the conversion. If you were replacing the lower skins you might get better access to the inside to do the conversion. You would need the pieces from the inside of the earlier door too.
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | The inside window frames are slightly different as well. The ones without the wing windows will not have the notch cut out. The window regulators are entirely differnt as mentioned. If it were me I would try to swap doors rather than go to all the work of modifiying the mechanics of it. | | | | | Joined: Oct 2007 Posts: 14 Apprentice | | Apprentice Joined: Oct 2007 Posts: 14 | Thanks to everyone who answered. I probably will change the doors rather than go to all that trouble. I didn't realize it was as involved a process as it truly is. Check out my website! http://www.1951chevy3600.com
MarcB
