Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Phak1, HandyAndy), 149 guests, and 3 robots.
Topics128,275
Posts1,058,574
Members48,492
Apprentice
Apprentice
Hey Guys! I have a 1951 3600 I am rebuilding. Budget is a major issue with me as it is with most people. My wing glasses are shot in every way possible and I am missing the frame from around the glass in one of the main windows as well as the inside window garnish from both doors. I was wondering if it would be cheaper if I just replaced the wings and the main glass with the one piece 1950 or earlier glass. I think the door itself is the same but is the door hardware the same? I hate to drop the big bucks on new corner glasses when authenticity isn't a concern since the truck is going on an S-10 frame. Any ideas and or suggestions are welcome and very much appreciated! Thanks to all and Merry Christmas
MarcB
Given that you have the turn-down type door handles I'd just swap doors from an earlier truck. No modifications required.
There are differences inside the door and the winder is different. Some people have down the conversion. If you were replacing the lower skins you might get better access to the inside to do the conversion. You would need the pieces from the inside of the earlier door too.
1951 1 Ton Completed
The inside window frames are slightly different as well. The ones without the wing windows will not have the notch cut out. The window regulators are entirely differnt as mentioned. If it were me I would try to swap doors rather than go to all the work of modifiying the mechanics of it.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Apprentice
Apprentice
Thanks to everyone who answered. I probably will change the doors rather than go to all that trouble. I didn't realize it was as involved a process as it truly is.
Check out my website!
http://www.1951chevy3600.com
MarcB
