0 members (), 89 guests, and 0 robots.
Topics128,049
Posts1,055,637
#35041 07/10/2003 3:04 AM
After several months of searching I finally bought a 52 Chevy short bed. It has a 235 that was made in May of '68 according to casting numbers. It has a 4 speed with granny gear but I don't know how to tell manufacturer and date. The markings are 1) J148 (October 14, 1958?) and
2) 591665.
I need to replace the throwout bearing but would like to know the make of tranny.
I am new to this forum but have done a lot of "surfing" and it's obvious to me that there is a great deal of knowledge among the members.
Thanks in advance for the help.
The project begins !
#35042 07/10/2003 3:06 AM
OK, I made a type already! The 235 was made in 1961, not 1968.
#35043 07/10/2003 7:36 AM
Only Toyota made the 235 in 68! grin As for id on your box, here's a good site for generals. Nowak tranny page As a rule, in GM's of this vintage the SM420 was used. Reverse is to the left and back. Around 67 the SM465 was introduced, reverse it to the right and back.
Fred
52 3600
69 C-10
#35044 07/11/2003 1:16 PM
Thanks for the URL info on trannies. Looks like we have a SM420. Does anyone know a surefire way to determine year of manufacture?
#35045 07/11/2003 9:17 PM
If you don't have the leftovers from a column shift and it is a torque tube setup, then it is likely original to the truck. Mine is.
Paint & Body Shop moderator
#35046 07/12/2003 3:18 AM
Tonight I was under my truck looking for leaks and noted the following numbers:
Here's whats casted on the side of my 4 speeder tranny:
4 E258
GM
591665
Here's whats stamped on the BACK of the tranny towards the top:
SM132903 P
Any ideas ?????
Craig
#35047 07/14/2003 1:57 AM
Cmayna,
Thanks for the numbers. That is consistent with the stamping on mine. Don't know what the date of manufacture is, but probably 47-60 or so.
#35048 07/18/2003 5:00 PM
420 were all made and used '47-'67 years
one PTO cover not two and is 1.5" in length difference from the 465
Randy the easter wabbit !
-here to help fellow enthusiasts as best as possible grin
parting some vehicles, 54 ford truck 57, chevy 210, 69 fairlane coupe HT and others,
