1 members (Hotrod Lincoln),
60
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#35041 07/10/2003 3:04 AM | Joined: Jul 2003 Posts: 141 Member | | Member Joined: Jul 2003 Posts: 141 | After several months of searching I finally bought a 52 Chevy short bed. It has a 235 that was made in May of '68 according to casting numbers. It has a 4 speed with granny gear but I don't know how to tell manufacturer and date. The markings are 1) J148 (October 14, 1958?) and 2) 591665.
I need to replace the throwout bearing but would like to know the make of tranny.
I am new to this forum but have done a lot of "surfing" and it's obvious to me that there is a great deal of knowledge among the members. Thanks in advance for the help. The project begins ! | | |
#35042 07/10/2003 3:06 AM | Joined: Jul 2003 Posts: 141 Member | | Member Joined: Jul 2003 Posts: 141 | OK, I made a type already! The 235 was made in 1961, not 1968. | | |
#35043 07/10/2003 7:36 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Only Toyota made the 235 in 68!  As for id on your box, here's a good site for generals. Nowak tranny page As a rule, in GM's of this vintage the SM420 was used. Reverse is to the left and back. Around 67 the SM465 was introduced, reverse it to the right and back.
Fred 52 3600 69 C-10
#35044 07/11/2003 1:16 PM | Joined: Jul 2003 Posts: 141 Member | | Member Joined: Jul 2003 Posts: 141 | Thanks for the URL info on trannies. Looks like we have a SM420. Does anyone know a surefire way to determine year of manufacture? | | |
#35045 07/11/2003 9:17 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | If you don't have the leftovers from a column shift and it is a torque tube setup, then it is likely original to the truck. Mine is.
#35046 07/12/2003 3:18 AM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Tonight I was under my truck looking for leaks and noted the following numbers:
Here's whats casted on the side of my 4 speeder tranny:
4 E258 GM 591665
Here's whats stamped on the BACK of the tranny towards the top:
SM132903 P
Any ideas ?????
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#35047 07/14/2003 1:57 AM | Joined: Jul 2003 Posts: 141 Member | | Member Joined: Jul 2003 Posts: 141 | Cmayna, Thanks for the numbers. That is consistent with the stamping on mine. Don't know what the date of manufacture is, but probably 47-60 or so. | | |
#35048 07/18/2003 5:00 PM | Joined: Oct 2002 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2002 Posts: 69 | 420 were all made and used '47-'67 years one PTO cover not two and is 1.5" in length difference from the 465
Randy the easter wabbit ! -here to help fellow enthusiasts as best as possible  parting some vehicles, 54 ford truck 57, chevy 210, 69 fairlane coupe HT and others, | | |
