Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (dt235sd, Sjm), 99 guests, and 2 robots.
Topics128,283
Posts1,058,505
Members48,490
#348569 12/14/2007 4:25 AM
1 Offline
ive been looking for a better rear end ring and pinion for my 49 1/2AD,im not in a hurry to find the gears so i have time to price em out.Jim Carters got 3.55 for 400.but for that price i could go get a axle from the junk yard.which leads to my question would i be better off buying the gears or an axle.do any other trucks have ring and pinion gears i can just swap in like a chevy 12 bolt.or would i have to do a whole axle conversion
I don't have a 1/2 ton, and don't plan to..
But I would swap the whole rear for a more modern one, for several reasons.
Better brakes, with easier and cheaper to get parts.
Loose the torque tube.
Cheap and readily available gears in many different ratios.
There are a number of rear axles that will work, and a search of this site will reveal them. The biggest thing to look for is one that is narrow enough, as most will be to wide. Will also want to consider bolt pattern and the wheels you want to use.
Just my thoughts, with no experience behind them....
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
a newer axle
the newer axles have much better brakes, allows you dozens of choices for trannys, open drive line and better freeway speeds.
b4 you buy an axle... consider:
what engine you will use.
what transmission ??
ratios ??
locate a transmission calculator to determine what axle ratio. works for your type of driving ??
engine mods ??
5 or 6 lugs ??
how much work do you want to do??
downtime spent on re-build??
do searches on this subject as it has been discussed many times over.
https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/showflat/Main/7628/Number/47910#Post47910
https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/showflat/Main/28553/Number/201341#Post201341
https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/showflat/Main/9025/Number/57576#Post57576
https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/showflat/Main/12612/Number/83783#Post83783
when you add a little more speed to your ride you should consider how to stop. yes you will
have better brakes in the rear. some day
you might get some more speed out of your new engine.
as you can see once you open a can of worms...
lots to think about.
I still have my stock front end but now sport disc brakes and a better brake system. this ALL takes time.
these are a tip of an iceberg on the subject..........
mid 70's 10 or 12 bolt axles work as do dozens of others
happy hunting... and good luck.
Jim & Caroline
---All pictures---
There is a whole list of which axles fit in the tech tips section.
However, you have to ask yourself:
What gear ratio do you want?
How much is fabricating a new driveline going to cost you?
How much is replacing the transmission with one with an open driveline output going to cost you?
How about doing the welding to make new spring perches?
If you have answers to these questions that either total less than $400 or you want a ratio other than 3.55, then you can do it. Otherwise it doesn't make economic sense, unless your present rearend is trashed, which is rare.
Paint & Body Shop moderator
While that could be true for some people, I think there are lots of other benefits to switching the rear axle. The cost of either option (old axle with new gars, or new axle) will be similar in price, but the added benefits of switching the entire axle can be worth much more.
The biggest benefit to swapping the entire rear is gaining an open driveline with more and better transmission choices that are then easier to install or swap. Better brakes are a good benefit too.
Grigg
---All pictures---
What are you going to do up front? If you want to match the rear you'll have to upgrade the front as well. I'm using a Chevy II rear & the IFS from a 79 1/2 ton. I had the rotors redrilled to match the rearend. Most of the Camero/Firebird units thru '81 work fine. Early Nova's work also. There are many choices out there but it depends on how you plan on using your truck.
Robert C.
I'm a Genius in the making.
1950 3600
1 Offline
im keeping everything original or close original 3 speed and a 62 235,also i dont plan on making any mods up front.it seems if im going to do an axle swap then i would need to switch to a open drive shaft,is it complicated and do any of the newer axles just bolt on or would i need to get new springs and stuff like that?
With your current setup to switch to a modern rearend, you will need find a donor rear the right width, get a different tranny, (closed tube three speeds can't be converted, 4 speeds can) fab and weld up new spring perches, (make sure to get the pinion angle correct) correct for the spring locating pin being too far forward (there are a couple ways to do this) and have a driveline made to fit. You also will need to figure out how to fab up the parking brake cables depending on which rear end you use.
To some this is not complicated, to others it would be. If this sounds like more you want to get into consider the 3.55 gears. Nothing modern will bolt right in. I believe that switching from the Huck brakes you have now, to Bendix ('51 and later) is a good upgrade. You can do this with your current axle. However, a lot of folks are happy with their Huck's. Good luck,
Steve O
1950 Chevrolet 3100 Deluxe Cab
Gallery Page
Webshots photos
Originally Posted by Grigg
Better brakes is a good benefit too.
This is one of the biggest for me. If you intend to use your truck in modern traffic you'll want to be able to stop with that traffic.
1 Offline
just wondering i saw a 51 3100 on classic truck.com that said he had stock 3.55 ring and pinion is this true and if so what year did they start to do this?
Apprentice
Apprentice
I tangled with the same question a few years ago. In the end I chose to swap out the original 5.14 gear in my 1 ton for a 3.90 from Patricks (www.patricksantiquecars.com). From my point of view swapping the gears seemed to be the easiest path. I can now hit 75 mph on the highway. The brakes work okay, but in a perfect world I would have upgraded them too.
Good luck.
Don't read the directions, that'd be too easy.
The guy with the "stock" 3.55 probably has the 3.55 gears installed in the original rear end which is what you are contemplating doing. Many people buy trucks and believe what PO's tell them and pass it on.
Just buying the ring and pinion is not the end of the story, you have 50 plus year old bearings, axles and other components to consider. Also, someone must be competent to set up the gears so they don't sound like a fire truck is following you. All this costs money and must be considered in the overall picture.
Fred
You can put the centre section from a 55 and later half ton right into your existing centre section keeping your existing axles. The ratio is 3.90:1, not as low as your existing 4.11. Its a bolt in swap and it will give you an open drive shaft. You would have to weld the spring perches.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
1 Offline
so all id have to do is get a pumpkin,new spring perches, and the drive shaft will mount up to my stock tranny?is the 3.90:1 good for highway use ive got a 235 stock 216 3 speed tranny,what are your rpms doing 65-70?
Punkin swap from 55. 55 to 63 I believe will work. Perches came off the same rearend or get them at tractor trailor supply when you buy new u-bolts (old ones cross the spring parallel to the rear end.
I chose this option as I kept original wheels, bolt pattern (6), axles, rear housing, brakes, etc. I changed to a T6 at the same time and had drive shaft made.
No yoke option I know of for swapping to a closed differential tranny tail. Might as well rab the tranny from the donor as well.
With stock 1954 235, 3:90 gears, 215/85/16's, and .73 OD gearong, I calculate 2219 rpm @ 70 mph.
and at 1:1 in 4th should turn 3040rpm @ 70 mph.
Send me a PM if you want pictures of the swap process or look at stepenwoods old truck sight.
Cavebull
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
If you want a brake upgrade, you really should do the front first. The front axle does about 80% of the braking because of weight transfer, especially without a load in the bed. There's nothing worse then your truck swapping ends because your back brakes locked up while your fronts just kind of sat there.
All,
I just reworked my fliker site and all truck work is viewable again - including 50 some odd shots of swap from 46 closed to 55 open driveline. Remember don't look to long at the shots of me welding. Same goes for safety glasses and my grinding pictures.
I accept no resposibility for possible injuries during viewing.
Brett
cavebull
IMO the swap to a later 3:90 center section is just not enough benefit for the amount of work involved as it won’t work with your stock tranny further opening up the can of worms. Changing transmissions will likely result in the loss of your column shifter and in turn convert your truck from a 3 passenger vehicle to only 2. As stated previously 80% of the braking is done by the front so that’s not much of a consideration either. Although not the cheapest way the 3:55 gearset along with new bearings, seals etc. will leave you with something that is highway friendly and “unmolested”.
Curt B.
You Tube
I have a 4 speed (floor shift) in my 52 and have no problems with two passengers. Not that any of the AD trucks are really 3 passenger trucks, at least not 3 full size people. The shifter does not make much difference either way.
Another way of putting it, I have never had to say "you can't ride with me because my truck has a floor shifter", never...
Grigg
---All pictures---
