| | | Forums66 Topics128,050 Posts1,055,632 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | `I have never taken of a steering wheel but now I am faced with this task. Is there a special tool that does this? I have removed the nut but it won't come loose. I am sure open to suggestions. sovagary
GS
| | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I bought the steering wheel puller set from Harbor Freight that cost me about $9.00 on sale. It has all the bolts and gear you need. Clean out the two threaded bolts in the wheel and then use the small pointed cap for the center bolt included in the kit. Tighten everything up and its loose in about 5-minutes using the included items. I assume you have a 47-54 AD, If not post with more information. | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | I just soak the steering wheel with penetrating fluid,PB Blaster/WD 40. Loosen the nut but leave it on covering the threads, get a helper, one sit in the seat an pull on the wheel near the spokes and have your helper smack the nut with a soft/brass hammer. Have had most pop off, Leave the nut on to save end of threads and your teeth!! Good luck Dan | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Use a steering wheel puller. If you don't want to buy one you can borrow one with a deposit at most chain parts stores. It makes no sense to beat on it. | | | | | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | Sorry I didn't give enough info. I have a '66 Fleetside. I just wanted to take it off to fix things below, turn signal, etc.I just painted the whole thing and like a dummy didn't plan ahead so now need to take the wheel off. Does this still apply? sovagary
GS
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, all the wheels are the same, 2 threaded holes to pull with a peg against the shaft end - simple to make your own outta scrap too Bill | | | | | | dgiorgi Unregistered | | dgiorgi Unregistered | I laughed when I read your trick to steering wheel removal Chev4t6... I always use the same procedure and without help I would pry the wheel up and down or side to side with both hands on opposites sides of the wheel always making sure to have the nut still in place and saving your teeth..LOL. | | |
