9 members (TUTS 59, 1955 1 Series, NJC, WICruiser, 51sub, greenie-reddy, Peggy M, Tronman, Gray_Ghost), 122 guests, and 2 robots.
Topics128,265
Posts1,058,360
Members48,485
#350177 12/18/2007 10:45 PM
`I have never taken of a steering wheel but now I am faced with this task. Is there a special tool that does this? I have removed the nut but it won't come loose. I am sure open to suggestions.
sovagary
GS
I bought the steering wheel puller set from Harbor Freight that cost me about $9.00 on sale. It has all the bolts and gear you need. Clean out the two threaded bolts in the wheel and then use the small pointed cap for the center bolt included in the kit. Tighten everything up and its loose in about 5-minutes using the included items. I assume you have a 47-54 AD, If not post with more information.
I just soak the steering wheel with penetrating fluid,PB Blaster/WD 40. Loosen the nut but leave it on covering the threads, get a helper, one sit in the seat an pull on the wheel near the spokes and have your helper smack the nut with a soft/brass hammer. Have had most pop off, Leave the nut on to save end of threads and your teeth!! Good luck
Dan
Use a steering wheel puller. If you don't want to buy one you can borrow one with a deposit at most chain parts stores. It makes no sense to beat on it.
Sorry I didn't give enough info. I have a '66 Fleetside.
I just wanted to take it off to fix things below, turn signal, etc.I just painted the whole thing and like a dummy didn't plan ahead so now need to take the wheel off.
Does this still apply?
sovagary
GS
yes, all the wheels are the same, 2 threaded holes to pull with a peg against the shaft end - simple to make your own outta scrap too
dgiorgi
Unregistered
dgiorgi
Unregistered
I laughed when I read your trick to steering wheel removal Chev4t6... I always use the same procedure and without help I would pry the wheel up and down or side to side with both hands on opposites sides of the wheel always making sure to have the nut still in place and saving your teeth..LOL.
Moderated by  ndkid275, Phak1
