0 members (), 40 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#349885 12/17/2007 10:16 PM
Ok, this may be a dumb question...
How do you remove the torque converter? I have removed the tranny from a '61 235 and the TC is still on the engine. How do you get it off? I pried a little, but I don't want to break anything.
1947 First Series Chevy 2 ton COE
2005 - It started in the Gallery
2023 - Follow the restoration in my Project Journal
1962 IH Scout 80
1982 Chevy Caprice Classic
If it is a Powerglide trans it will have 3 bolts on the front side of the flex plate. You will have to rotate the engine to get to them.
Fred
3B Offline
Hy Farmdog, there should be 3 bolts holding the torque converter to the flywheel, they install from the engine side toward the transmission side, hope that helps.
Thanks. I'll look for those if I can get the engine to turn. I noticed there was a hole on the front side to see in.
1962 IH Scout 80
Just a footnote, when you reassemble, install the torque converter in the transmission before you attach it to the engine. Pay carefull attention to the instructions in the shop manual to get it installed correctly to engage the pump and not damage the seal.
Fred
Thanks, but I don't think I'll be re-installing it. I will be using this engine for parts. I'm not a big fan of automatics anyway.
1962 IH Scout 80
