1 members (Hotrod Lincoln), 69 guests, and 2 robots.
Topics128,135
Posts1,056,423
Members48,441
#347313 12/11/2007 3:01 AM
1 Offline
I dont know much about wood, my buddy is going to make me a custom wood bed for my 51, Has anyone ever used Mahogany before ? What's your thought's
Todd
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
1Bad51 #348704 12/14/2007 5:03 PM
Mahogany is pretty soft - will mark easily if you plan on using the bed at all. It also has an " open " grain - soaks up water easily. If its for show only would look good - otherwise I'd go to a harder wood.
1940 Chevy KC 1/2-Ton
What britcon said
1952 Chevy Shortbed
Photos in Photobucket
What SW Radial said
1 Offline
Thanks for the info... This is going to be my everyday Driver But the most it will ever haul in the bed is "maybe" a few groceries (as long as there's nothing in there that wont spill) Lol !
1Bad51 #351356 12/22/2007 5:37 AM
If you really never use it, then mahogany would be fine. You will want to seal it on both sides with some sort of finish. could learn something from the fancy wooden boats, as many of them are/were mahogany, used very near water, and need to look good.
I would go with a harder wood though.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Grigg #351633 12/23/2007 1:23 AM
U
U Offline
Best to replace bed wood with white ash. Too many people replace the wood with oak, thinking that was what was used originally. Oak reacts with moistuer and will swell and cup, it was never used for bed parts for this reason. Apitong, maple, cherry or ash will stand the hard use and not change dimension in weather.
uncleb #351923 12/23/2007 11:26 PM
Yellow pine is what was originally used and is durable and long lasting.
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
Heres my 2 bits I redid my bed using the original oak uncleb is right oak cups, but I didn't want to redo all the wood so I stained it mahogany and I think it looks good... See my pictures on the link below... Peter
Mahogany wood is a hardwood.It should do great in a pickup bed. Be sure to put a good urethane on it.The wood boats of yesterday were built of mahogany,lasted forever when taken care of.Just my thoughts !!!!!!!
1951 3100 Chevrolet
I have already submitted my $0.02, can I put in two more?
While Mahogany is technically a hard wood, it is soft in comparison to many other "hard" woods. I still think it would be a good looking bed, but not durable for a work truck. That said, it would probably last fine, but look really bad after it is nicked and scratched repeatedly. A physically harder wood, like oak, will look better for longer if the truck is used as a truck.
Most all woods will cup if you choose the right grain orientation to allow it to do so. for oak it won't cup at all if it is finished in the same way the same on both sides, and it is true "quarter sawn". Quarter sawn wood is like looking at the end of the log and taking a piece of pie out of it, and make that piece parallel in thickness, not a piece of pie now, but you get the idea of how it comes from the tree. Generally quarter sawn wood is more stable, but some woods benefit from it more than others, it really helps oak to stay flat.
For my truck, a real work truck, and also for show, I will use quarter sawn white oak. It will stay flat, last a long time, and look great. Many other types of oak are not rot resistant like white oak is. Being quarter sawn will make it look great, and help prevent cupping. I will also allow space between the boards for them to swell and contract without binding and forcing a cup. The SS strips will hold them down, and mask the unavoidable seasonal movements (changes in width) length changes very little with moisture changes. SS as opposed to regular steel will look better because dark stains won't form where the oak touches the metal.
Another important thing when choosing wood is to be sure it is dry, but not to dry. Best to let it sit in the shop and normalize for a few months if you can.
I go to get my bed wood this week, it will be green, so I will stack it and sticker it to dry, and tie the bundle together with ratchet straps to keep them flat, snugging them up regularly. in a few years when I am ready to use them I'll joint, rip, and plane to final thickness.
There are so many wood choices out there, and some I think are better over all than oak. Even though I could get most of these different, fancier, and/or imported woods, white oak is the look and durability I want for my truck.
For as many different kinds of people and their trucks, there are probably that many wood choices too, so pick the one you like for whatever the reasons, but it can't hurt to do some research on it's quality's before the final decision.
That may have been $0.04, oops blush
Grigg
---All pictures---
Mohogany is a woodcarvers dream because it is easy to carve i.e. soft, but it looks gorgeous when finished. If I had the money I would use teak. Teak is hard as a rock and has a lot of natural oil and silica in it which helps it stand up to water. Give me a boat made from teak any day.
