3 members (baldeagle, Jon G, Peggy M), 241 guests, and 5 robots.
Topics128,106
Posts1,056,214
Members48,436
#347557 12/11/2007 8:21 PM
What's the best way to paint the steering box? I was gonna use Zero-Rust. Would that be enough? Or should I use something on top of that? Or something completely different all together?
You could use zero rust and then cover that with rustoleum or POR-15.
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now.
http://www.coxcustomcars.com/
I used a product called "Right Stuff" bought at local FLAPS. Worked well after cleaning. Then I painted with Rally wheel silver. Pics Below
Dan
http://rides.webshots.com/photo/2814995750071274430uyBMjN
i sand blasted the steering box and column and por 15 the box and column up to the firewall. drilled and tapped the column for my tach-o-meter and blinker arm and painted the rest of the column is interior cab color. i also re-greased the upper steering column bearing w/ grease.
i sealed the steering box first w/ black silicon sealant
Jim & Caroline
Hey Chev4t6: has my wife been there? She leaves her soda cans on my fenders all the time.
Tango,
Does your wife drink Canada's "adult" beverage? If so she could have been here!!!!!!
Dan
