4 members (Jaison, FAST55, RdsLessTaken, 1 invisible), 152 guests, and 0 robots.
Topics128,161
Posts1,056,921
Members48,458
I am in the process of putting a T-5 and modern rear end in my 37 and I am putting in new rear springs while its apart,I can imaging the bushings might be a little hard to get out since being in for 70 years and would like to hear some ideas on how to get them out easy. The idea I have is to cut a slot in the bushing to relieve tension so it will drive out easier,I bought a air saw with thin blades to cut the slots but if anyone has a better idea let me know. Jeff
You Tube
Used the same trick, only I used a 1/2" bolt instead of 3/8". If you get some washers larger than the bushing, you can use the same bolt to install the new ones.
Bill Burmeister
on the other side of this thought......
when re-installing new bushings in my AD. The replacement bushings for AD's are different than original issue. So i ground down the raised serrations on the new ones because the first one i tried to install was SO hard to push/draw into the frame flange, grinding down the raised edges bushing was a time saver. i did use a big "C" clamp. BTW the bushings are both secure.
Jim & Caroline
When installing the bushings I was going to stick them in the freezer for a week before installing them to see if its any easier. Jeff
Ex Hall Monitor
Ex Hall Monitor
Would a large "C" clamp work to "press" the bushing in?
''Would a large "C" clamp work to "press" the bushing in? ''
yes
& press /push it out. .... as curt b showed above in tech tip.
but freezing them vs. time it takes to install them is taken up by the install time. many don't heat the frame anyway. They are not a tight tolerance fit as they just hold a pin and allow it to move in a very short arc, fit isn't critical. that's why the newer ones have a raised serration all around the dia.
http://www.classicparts.com/prodinfo.asp?number=74-008
zoom in to see photo
Jim & Caroline
I tried the carriage bolt and the bushing moved but the bolt stripped,I tried to find a hardened one but the hardware store did not have any. I am going to see if I can get a large enough bolt to thread into the bushing and get it out that way but if that does not work I will get a regular hardened bolt and try to get it out that way before cutting it out. Jeff
Put some anti-seize or grease on the threads. Sockets may work good for spacers and an impact gun is handy too.
You Tube
Ex Hall Monitor
Ex Hall Monitor
You might try a grade 8 bolt & washer the correct size. A grade 8 bolt will be a LOT less likely to strip (use a grade 8 nut too).
This tool from Harbor Freight makes it a short, almost pleasant, job.
3-IN-1 BALL JOINT/U-JOINT/C-FRAME PRESS SERVICE KIT
Here's a pic using it on my truck with a impact wrench providing the muscle.
C-Frame Press and Impact Wrench combination
Larry Kephart
1937 Chevy Utility Express (Deerslayer)
1955 1st 3100 Chevy (BillyBob)
2017 Cadillac ATS-V (Elvira)
Boca Raton, Florida
e-mail: [email protected]
http://www.laroke.com/larryk4674/1998/billybob.htm
The bushings are out and I ground off the knurled part of the new bushings and they are in the freezer,I got a hardened bolt and that did the trick. I never understand why they cant make bolts with threads all the way up as I had to cut them up to the head. Jeff
