5 members (Gray_Ghost, 49choptop, Guitplayer, pauld, Forty9), 101 guests, and 4 robots.
Topics128,201
Posts1,057,281
Members48,467
Its been bored .040 over and was just wondering what the cubes would be? Should be getting close to 300 cu in I would think. With a 4.125 stroke it should be a puller.
3B Offline
Hy Henry G I come up with 297.7888, so lets call it a 298, hope that helps.
Displacement = pi/4 x bore(2) x stroke x number of cylinders
pi/4 = 0.7853982
Thats; bore (squared)
Have fun, Joe
All you need to do is figure out the volume change and add it on. The change would be (.040" /original dia bore). Multiply the result by 292 and you have the increase. For instance if the original bore was 3.5", then the change would be ((.040/3.5)* 292) which works out to 3.337 cu in. I think the figure in the posting above is what you will get.
1951 1 Ton Completed
pi x r2 (radius squared) X h (stroke) x no. of cylinders.
cgresham1212
If you don't drive it, why have it?
55 1st Series 3100 5 window
