1 members (carbking),
144
Mod | | | Forums66 Topics128,186 Posts1,057,211 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 202 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 202 | Its been bored .040 over and was just wondering what the cubes would be? Should be getting close to 300 cu in I would think. With a 4.125 stroke it should be a puller. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Henry G I come up with 297.7888, so lets call it a 298, hope that helps. | | | | | Joined: Feb 2000 Posts: 5,237 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,237 | Displacement = pi/4 x bore(2) x stroke x number of cylinders
pi/4 = 0.7853982
Thats; bore (squared)
Have fun, Joe
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | All you need to do is figure out the volume change and add it on. The change would be (.040" /original dia bore). Multiply the result by 292 and you have the increase. For instance if the original bore was 3.5", then the change would be ((.040/3.5)* 292) which works out to 3.337 cu in. I think the figure in the posting above is what you will get. | | | | | Joined: Nov 2004 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 117 | pi x r2 (radius squared) X h (stroke) x no. of cylinders.
cgresham1212 If you don't drive it, why have it? 55 1st Series 3100 5 window
