0 members (),
75
Mod | | | Forums66 Topics128,211 Posts1,057,475 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Pleeeease don’t throw me out of here Charlie or woo, I’ve had this quest posted in the radio forum but you know not many guys browse that forum and this is “directly related to the care, restoration, preservation or use of old GM trucks!”. Desperately searching for a digital picture of the “model/tube compliment/patent pending paper label” for an AD original AM radio. It may be on the side where the wires enter the chassis on the slant back or inside the back cover on the straight back ones. Just a picture guys! Thanks Santa, Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | have you checked here?Bill | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Denny I stuffed my fat head under the dash and couldnt see a label. You say there could be a label inside? Mine is the straight backed case. Ill pull it if it could be of help but Id like to make sure I understand correctly first.
Jeff | | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | Denny, drop this gent a email he is the radio garu for the VCCA. He should have the info that you seek or know where to find it. Raymond Holland E-mail Address(es): [email protected]
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yes Jeff, it should be inside the back cover on the straight-backed radios. There are two screws at the bottom then it swings out and the top has two bumps in the case that the back hooks over. I know it's a pain in the arss and I wouldn't ask my best friend to do it if it weren’t for the fact that I'm one of those darn perfectionists and want to add the finishing touch to the restoration of these two radios I have on the bench. I would really appreciate it if you found the ambition to check that. I need a high-resolution picture so I can read the tiny text. It's down about 1pt or 2pt in size.
I'll shoot an email off to Ray, but I have tried contacting the VCCA tech advisors on several occasions and never got any replies back. I joined about a year ago but that didn't seem to make any difference.
| | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | Denny, I understand I have been a member for about 12 years and I still get the feeling that some of the tech advisors seem to not want to part with alot of the info that they have. Best of luck.
| | | | | Joined: Jun 2007 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 120 | Denny: I took the cover off my radio in Ol Yeller. ('52 3100)The paper says: Pontiac Model 984570. I will get a photo posted here in a minute, if in fact this is the piece you want. It has a schematic of the tubes and their cooresponding numbers and about a million patent numbers. Is this what you want?
Mitch | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yes Mitch, the patent numbers are in all likely hood the same for this model chassis as for the Chevy, GMC, Olds. Usually all that is changed is the location and style of the dial mechanism and the part numbers. If you could attach a high resolution close-up picture of the label I'd appreciate it. And thanks for going to all this trouble, I know it's a bit much for a lot of people but it is the finishing touch on a high quality restoration in my opinion. I’ve already got the label roughed out in Illustrator from the following tip that Scott gave me for one that was an ebay radio. It had a picture of a Chevy 986443 label but it's to blurry to make out the fine print like the patent numbers. Finding the correct fonts is the biggest headache when reproducing one of these labels. I’ve done many many of them for the table radios that I have restored. Thanks again,
Ya ever drivin a Pitts???
| | | | | Joined: Jun 2007 Posts: 120 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 120 | Pitts, no. Marchetti YES! More about that later. Yeah I got under the dash last might to get out of helping our 22 year old move to an apartment. Look in your personal email. I sent the Hi-Res pics to that address. (Hope that was ok) If you don't get them let me know. | | | | | Joined: Jun 2005 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 46 | Denny, I have what you are wanting, email me at [email protected], I'll send it your way | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | G'day and tks, 380B! Denny G
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Craig, Mitch and Scott, thanks guys, I've got the jpegs downloaded and they are wxactly what I was looking for. Now I can finish the label reproduction. "All things come to he who waits". Thanks for the Christmas presents guys, and have a happy holiday. Denny Graham Sandwich, IL
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | OK, now that you have what you need, I'm moving it to the Radio forum for future reference. How about posting a link to the finished product? | | | | | Joined: Jul 2006 Posts: 327 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 327 | Yes lets see what you were looking for post the J PEGS here pls Danny.... Thanks Peter | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | That’s peachy Charlie, thanks for leaving it up, it helped a bunch. That be Denny Peter, Danny's my brother, remember, I'm that bloody perfectionist. They’re not finished yet, they have to be treated to keep the ink from running when I apply them with the mucilage glue, but this should give ya all an idea of what’s involved when you obsess over something: http://rides.webshots.com/photo/2458332170098611668XjCxij Oh those little details!!!! Denny Graham Sandwich, IL
| | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Its those little details that need to be kept from being forgotten! Its so much more work to restore then it is to change, upgrade. etc. Im not as anal about it as you are but I can sure appreciate the time involved.
Glad you found what your looking for and good luck!
Jeff | | |
