3 members (Stewart2, 55shaker, 1 invisible), 145 guests, and 3 robots.
Topics128,165
Posts1,057,010
Members48,458
#34564 05/04/2005 2:56 PM
I have a 1965 chevy truck. It has a straight 6 in it . I would like to know how to tell if it is a 230 or 250. I have been told it was both by differnt people .please help
here are block casting numbers fro the two engines, 230 from 1963-'65, #3788406, 1966-'70 230, #3850817, 3854036, 3877178, 3921968
250 from 1962-'79, 328575, 348675, 366855, 377172, 2775308,3850817,3854036,3877178,3921968
As you may notice they used the same block thru some of the years. The crank and pistons are different. You may have to take it apart to no for sure! They even used the same same head on some of them.
Joe H
X
X Offline
You can also tell what engine it is by the type designation in the serial number (the one or two letter suffix).
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
Look for the stamped number on the pad by the distributor. Last 2-3 are the engine code.
http://no25.homestead.com/page3.html
