here are block casting numbers fro the two engines, 230 from 1963-'65, #3788406, 1966-'70 230, #3850817, 3854036, 3877178, 3921968
250 from 1962-'79, 328575, 348675, 366855, 377172, 2775308,3850817,3854036,3877178,3921968
As you may notice they used the same block thru some of the years. The crank and pistons are different. You may have to take it apart to no for sure! They even used the same same head on some of them.
Joe H
