1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 55 | Since adding the Petronix unit to my distributer I now have major noise coming from my original radio. Is there a supressor or condensor that might help this problem? Thanks, Bert
Greater love have no man than this, That he let his wife drive his truck to the grocery store. ........
| | | | | Joined: Jan 2007 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 44 | hello burt yes yhter is a such thing as a noise cancilation filter go to your local electronicvs supply ie radio shack and ask for a moise cancilation filter that goes in the wiring for your alternator, you also have a late model alternator in 12v dont you have fun mojaveb
| | | | | Joined: Mar 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 55 | No. I still have the generator. I thought you couldn't put anything on the generator. Any more suggestions? Thanks for your help, Bert
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | You could try radio frequency suppression spark plug cables and resistor plugs. I believe that may help. | | | | | Joined: Mar 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 55 | Thanks. Already installed. No difference in sound quality.
| | | | | Joined: Jun 2007 Posts: 90 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2007 Posts: 90 | If you don't have them already, put a condenser on the BATT terminal of your regulator and the ARM terminal of your generator. I gather from reading your posts that you don't have and one your generator. There may be noise coming from your Pertronix module but rest assured if you don't have condensers in your charging system you're getting noise from there too. Any regular 'ol ignition condenser will work, just ask for it at your FLAPS.  | | |
