7 members (cmayna, Leo, Hotrod Lincoln, Mike in Sycamore, Gdads51, 1955 1 Series, Bill Trotter), 127 guests, and 1 robot.
Topics128,113
Posts1,056,280
Members48,439
8
8 Offline
Since adding the Petronix unit to my distributer I now have major noise coming from my original radio. Is there a supressor or condensor that might help this problem? Thanks, Bert
Greater love have no man than this,
That he let his wife drive his truck to the grocery store.
hello burt yes yhter is a such thing as a noise cancilation filter go to your local electronicvs supply ie radio shack and ask for a moise cancilation filter that goes in the wiring for your alternator, you also have a late model alternator in 12v dont you have fun mojaveb
8
8 Offline
No. I still have the generator. I thought you couldn't put anything on the generator. Any more suggestions? Thanks for your help, Bert
You could try radio frequency suppression spark plug cables and resistor plugs. I believe that may help.
8
8 Offline
Thanks. Already installed. No difference in sound quality.
If you don't have them already, put a condenser on the BATT terminal of your regulator and the ARM terminal of your generator. I gather from reading your posts that you don't have and one your generator. There may be noise coming from your Pertronix module but rest assured if you don't have condensers in your charging system you're getting noise from there too. Any regular 'ol ignition condenser will work, just ask for it at your FLAPS. smile
1960 GMC Panel w/ 305 V6, 4 Speed TV Repair Van "The Monitor Lizard"
1961 Chevy Apache 20 283, 4 Speed, Hydrovac
www.picturetrail.com/starchief
Moderated by  truckernix
