3 members (cmayna, Ponchogl, Hotrod Lincoln), 105 guests, and 0 robots.
Topics128,126
Posts1,056,351
Members48,441
#344378 12/03/2007 10:12 PM
Hi All,
My 1/2 ton '54 panel front doors are off the truck. I am ready to install them and was wondering if it is easier to leave the rubber off the doors until they are adjusted? The body rubber is already in place. Thanks for the help.
All the best, Ted
Definitely put the rubber on the doors while you have them off the cab. The rubber isn't an adjustable element, and adjusting the doors without the rubber on means you'd probably have to do it again when you put the rubber on. Also, it's nearly impossible to get the rubber on neatly on the hinge side of the door with the doors on.
I just finished putting thr rubber on the doors for my '48 last week, and it was difficult enough with the doors on sawhorses.
Good luck!! wave
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
Ditto on what Tom said
1952 Chevy Shortbed
Photos in Photobucket
Especially the fitting part. You would be amazed at how much pressure that much seal can exert on a door.
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
