10 members (Donf, Bogart's Truck, jmoore, Gdads51, TexasA&M48Truck, kades51, Otto Skorzeny, Frank50, Jon G, 1 invisible),
105
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,132 Posts1,056,379 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 102 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 102 | Hi All, My 1/2 ton '54 panel front doors are off the truck. I am ready to install them and was wondering if it is easier to leave the rubber off the doors until they are adjusted? The body rubber is already in place. Thanks for the help.
All the best, Ted
| | | | | Joined: Jul 2005 Posts: 640 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 640 | Definitely put the rubber on the doors while you have them off the cab. The rubber isn't an adjustable element, and adjusting the doors without the rubber on means you'd probably have to do it again when you put the rubber on. Also, it's nearly impossible to get the rubber on neatly on the hinge side of the door with the doors on. I just finished putting thr rubber on the doors for my '48 last week, and it was difficult enough with the doors on sawhorses. Good luck!!  | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Especially the fitting part. You would be amazed at how much pressure that much seal can exert on a door. | | |
