6 members (Hotrod Lincoln, MikeE, 55shaker, Otto Skorzeny, Philipj, 1 invisible), 129 guests, and 4 robots.
Topics128,148
Posts1,056,810
Members48,454
Apprentice
Apprentice
I have a 1965 chevy pickup and i would like to switch it out to power steering. I like to drive the truck but it would sure make it easier to drive with power steering. I was just wondering what I would need to do and if it was worth it.
Thanks Justin
1965 Chevy C-10
All Original
You have a few options. Find a doner truck with power steering and salvage all the necessary parts. Buy an aftermarket kit or subframe with a camreo,nova, monte carlo, etc. All but the subframe are just parts swaping and not too big a deal. Good luck with your project.
On a 63-66 it is not that difficult. You can use any GM truck power steering box up to about 86. You will need to get a Rez kit to mount the box off the frame. The later trucks have a dimple in the frame for the box the Rez kit solves that and it is available most of parts dealers in the links here. If you have a six life gets a little more difficult finding brackets to mount the pump. If you have a v8, it's just a matter of finding brackets to line every thing up. Some of the later stuff is metric, there are work around.
Larry
I don't own a vehicle that isn't old enough to drink.
Apprentice
Apprentice
Hey guys thanks for the info. I will let you know what i find. And i do have a inline six. So i figured it might be a little harder.
1965 Chevy C-10
All Original
I've seen the brackets for the 292 six go for as much as $200 on that auction site. The 292 has a taller block and the PS was not as common on them. Get all the pulleys, including water pump. Brackets were also made for the integral and don't fit the earlier heads. Best of luck in your search.
Larry
Socket Breaker
Socket Breaker
REZ Engineering - No website yet, call or write - power steering kit. used trucks to part out(particularly 4x4). 1960 - 1966 Chevy/GMC. - PO Box 1584 - Great Falls, Montana 59405 - Ph. 406-727-9267
http://www.persh.org/pickup/steering.htm
Rez Engineering EZ Steer Instructions <-- are on that site, the link is in the lower left corner.
here is an article from a truck mag about installing the kit:
http://www.customclassictrucks.com/techarticles/60_66_chevy_gmc_power_steering_retrofit/index.html
My old '65 truck already had power steering on it, when I bought it. It makes it very, very nice to drive. I've driven a similar model truck like mine, a long bed which was still manual. It is a world of difference.
good luck,
-W
