2 members (Charles in CA, Woodcmiami), 151 guests, and 5 robots.
Topics128,266
Posts1,058,385
Members48,485
Apprentice
Apprentice
Ive seen these water pump adapters and was just wondering when one should use them?would i need one if im switching my 216 to a high press 1960 235?and where would you guess recommend to buy these at?
Jim Carter sells them
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
If you do not use the adapter and settle for the short shaft waterpump it will look like this:
http://rides.webshots.com/photo/1377765981023244788uDinRU
The fan barely misses the balancer and is low in relation to the radiator. It works for me but only after adding a shroud to capture more wind. Individual results will vary. The adapter plate will move the fan up closer to the center of the rad. Here's another source for it:
http://cgi.ebay.com/ebaymotors/1955...201QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
You Tube
