4 members (UtahYork, jmoore, TUTS 59, 68ironhead), 92 guests, and 4 robots.
Topics128,026
Posts1,055,404
Members48,422
#344179 12/03/2007 4:52 AM
Hi All, I have the usual foggy around the edges windows in my 51 3600. I was wondering if anyone has ever tried putting the windows in an oven and heating them up to see if the moisture could be driven out and to see if the glass laminate would reseal. How about heating them in a vacuum. Anyone ever tried such a thing?
Rick
Rick In VA #344223 12/03/2007 10:30 AM
Rick,
I would bet with that old Glass that if you heated it in an oven it would completely delaminate ...the Glass is OLD ....and the plastic between the layers has seen its length of service.
You would be further ahead since your glass is intact and you have it out or gonna take it out it would be best to take em to your local Glass shop and have replacements cut using your glass as a template, being flat glass the cost should outweigh the hassle ??
Just my thoughts
Tim
1952 Chevy Shortbed
Photos in Photobucket
Good thought Tim. I had never considered having a glass shop make up the glass. All of the glass is in bad shape and the cost to buy all the glass form the normal vendors is quite high for my budget. This could be a viable alternitive, thanks!
Rick
Last time I had flat glass cut it was $35/ a piece. Its about the cheapest thing you can have done now adays.
Paint & Body Shop moderator
I had a broken front glass in my 50 and had it replace by a local glass shop. The other side of the windshield was not in great shape and the one piece of original glass I had was delaminating. I got them to do both sides and it was a good decision. Cost a lot less than replacement glass and using the old glass as templates it was a great finish. Danv
