| | | Forums66 Topics128,042 Posts1,055,518 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 222 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 222 | Hi All, I have the usual foggy around the edges windows in my 51 3600. I was wondering if anyone has ever tried putting the windows in an oven and heating them up to see if the moisture could be driven out and to see if the glass laminate would reseal. How about heating them in a vacuum. Anyone ever tried such a thing? Rick | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Rick, I would bet with that old Glass that if you heated it in an oven it would completely delaminate ...the Glass is OLD ....and the plastic between the layers has seen its length of service. You would be further ahead since your glass is intact and you have it out or gonna take it out it would be best to take em to your local Glass shop and have replacements cut using your glass as a template, being flat glass the cost should outweigh the hassle ?? Just my thoughts Tim | | | | | Joined: Feb 2006 Posts: 222 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 222 | Good thought Tim. I had never considered having a glass shop make up the glass. All of the glass is in bad shape and the cost to buy all the glass form the normal vendors is quite high for my budget. This could be a viable alternitive, thanks! Rick | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Last time I had flat glass cut it was $35/ a piece. Its about the cheapest thing you can have done now adays.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Aug 2005 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 28 | I had a broken front glass in my 50 and had it replace by a local glass shop. The other side of the windshield was not in great shape and the one piece of original glass I had was delaminating. I got them to do both sides and it was a good decision. Cost a lot less than replacement glass and using the old glass as templates it was a great finish. Danv | | |
