3 members (dt235sd, BC59, 1 invisible),
94
Mod | | | Forums66 Topics128,211 Posts1,057,471 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 28 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 28 | Just received my '55 2nd series kit, and noticed it mounts differently than most other vendors kits. Instead of the usual triangle bracket welded to top of the frame, it has a longer bracket, with two bolt holes. This actually raises the gearbox 1 1/2" higher. Instead of the normal 3 bolts thru the frame, this kit only has two bolts in the frame itself, and two thru the welded bracket. Was wondering if this was the right bracket, and how raising the gearbox would affect the geometry of drag link, etc. etc. Anyone used this kit?? Thanks. | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | Marc, There are a wide range of kits out there for various type PS conversions. What type of gear box are you installing? Saganaw, Toyota, Other? Fred
| | | | | Joined: Apr 2005 Posts: 28 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 28 | Sorry, the Saganaw gearbox. | | | | | Joined: Aug 2007 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 121 | i installed the sagnaw box on my 53. with the longer bar welded to the top of the frame. it looks good the company i bought my kit from sold me the instsall kit drag link and pitman arm it is all made to work together all the geometry is correct.but double check the mesurments in the directions mine would have set the box 1.5 inches off and nothing lined up and the drag link was to short if installed using the directions. if you want i can post some pics of my install for you
gotta love old trucks
| | | | | Joined: Aug 2005 Posts: 113 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 113 | 53Chev,
I'd like to see pics of your install. I'd like to do the same to my '59 in the near future.
Lane | | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | I did a power steering kit on the 59 from Chevy Duty years ago and the kit that you describe sounds different then the one that I bought awhile back. The one that I bought mounted very easy. I used a steering box off of a late 70 chev truck and a pitman arm off a 70-72 Malibu. The kit works great but I did have issues with bump steer after installing. To fix the problem I flipped the tie rod on the drag link to make it more level and that fixed the bump steer issue.
38 original 48 panel 59 stepside 46 in the back forty
| | | | | Joined: Aug 2007 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 121 | i will take good pics and post them on photo bucket.com i have some posted not too good look under justin53chev. i will post more this week
| | | | | Joined: Aug 2007 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 121 | i havent forgoten you i havent had a chance to get pics. long story bought car thought it was good spent all weekend working on it
| | | | | Joined: Aug 2005 Posts: 113 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 113 | 53chev,
Any luck with those pics yet?
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Classic parts shows 2 different kits in their catalog. This post is interesting because I would like to do my 58 one of these days. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Aug 2007 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 121 | well i cant figure out how to post pics i have them at photobucket.com under justin53chev. if someone could tell a dummy how to post pics on this site. i will if not at least you can go there sorry it took so long.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Go to full reply screen and the first button creates a link. Post the web address and a title. Your pictures. | | | | | | Dave Giorgi Unregistered | | Dave Giorgi Unregistered | thanks for asking 53chev...now I know...
