| | | Forums66 Topics128,211 Posts1,057,472 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2005 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 83 | So after a year or so of driving my 64 w/ 4spd I finally beefed it and tried starting the truck in gear w/out putting in the clutch. It lurched forward and I caught it immediately; no fatalities this time. But ever since I've been having a problem with the starter. About 80% of the time I go to start it, everything's in fine working order. But the other part of the time the starter will just whir around like the solenoid isn't engaging the starter gear to the flywheel. Also, regardless of the starting condition, when I let out the clutch to let the rig idle in neutral I feel a slight pull forward as though it were in gear. For the love of god, what have i done to my poor truck?!! | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | The contacts in the selonoid are probably burnt. | | | | | Joined: Oct 2005 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 83 | so could I flip that big copper washer over in the solenoid and be good to go, or am I just out of a solenoid? | | | | | Joined: Aug 2007 Posts: 156 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 156 | You may have busted a tooth off the flywheel. I had that happen to me. | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | I would try flipping the washer before buying a new one. The part about the tranny pulling in neutral sounds more like something could amiss in the tranny. If it shifts OK and isn't making any undo noises it's probably OK. Are you sure it wasn't doing it all along & you just weren't as sensitive to it because you weren't looking for anything wrong?
| | | | | Joined: Oct 2005 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 83 | yeah, i'm positive the grab is new, but the engaging problem worries me worse than anything. Between tips from the guys here and troubleshooting guides I've narrowed it to solenoid contacts or starter drive. Regardless, I will rebuild the starter--it's an original off a '66 i scrapped, and i like to use the old stuff...and squeeze pennies. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | If it's a broken tooth on your starter ring you can check it out by Putting the tranny in gear (1st) and pushing (bumping) the engine over just a bit. If it's a tooth missing that will move the starter ring teeth over enough to get it to start.
~Jim
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I think you have a busted tooth too. The reason it only effects it 20% of the time is when the bindex lines up with the missing tooth. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | If you have a flywheel inspection cover you can remove that and look for broken teeth. | | | | | Joined: Oct 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 52 | It sounds like the bendex spring may have broken and will allow the starter gear to be stuck on the flywheel sometimes other times the gear wont throw out..check the bendex for damage or replace the entire starter. James
| | | | | Joined: Oct 2005 Posts: 83 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 83 | | | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | You would have to be missing at least two adjacent flywheel teeth to keep the drive from engaging, and you'd never get more than one turn of the engine before it set up a horrendous grinding noise, or stopped turning. The copper washer is no longer reversible- - - -only one side has a copper coating on an otherwise steel washer. That change has been incorporated into solenoids for at least 15 years, maybe longer. Don't know what you'll do with the burned contacts in the end cap, as they're not reversible any more, either.
It sounds like the one-way clutch in the starter drive is slipping occasionally. if you decide to repair the starter instead of installing a rebuilt unit, do it right, with new brushes, machine the armature, change the front and rear bushings, new solenoid linkage, install a new or rebuilt solenoid, and a new starter drive. You'll only pay about 50% more than a good rebuilt starter will cost that way, and be sure to charge out your labor time at about $5.00 per hour! Jerry
| | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | I have a question. Why do that? I understand if a system or sub-system fails that you may have to do something out of the ordinary. That seems like hammering a nail into a board without turning loose of the nail, then not understanding why your fingers hurt. Am I missing something here? | | | | | Joined: Feb 2004 Posts: 29,889 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,889 | Doing a patch-up job on a starter with enough time and wear on it for the drive clutch to start slipping without addressing other normal wear areas like the brushes, bushings, and solenoid linkage is false economy. It takes almost a complete teardown to replace the drive unit. You'll probably be money and time ahead to swap for a good-quality rebuilt starter, or get a new, lifetime warranty unit and make it the last starter you'll ever pay for on this vehicle. Jerry
