4 members (Goach2, Cletus1950, Wally / Montana, Bill Hanlon), 82 guests, and 3 robots.
Topics128,173
Posts1,057,041
Members48,458
Apprentice
Apprentice
I have a 1969 C60 Slower then all get out, i want to take the old 4 spd out and put in a five or 6 or 7 speed in, as well as get a long geared rear end with out the 2 speed. can anyone help me out with what i should be looking for.?
Here are a couple of things that would have been original to your model that you may want to consider for the swap.
Common 5 speeds in C60-C65's were Clark 282 and 285 models. Rear ends are determined by capacity and basically what I remember is that the 15K w/ 2 speed was a vacuum operated Chevy rearend. The 17500, 21K were Eaton electric operated 2 speeds. I doubt you'll find any 21K's in C60's but a ton of them had 17500's. Very common farm trucks with 7K front axle's, 9:00 rubber and 6:50/7:17 rear ratio. Hope this is of some value to you.
ps...you didn't say what your truck now has but the assumption is that it is a single speed rear, (?) The model and ratio may still be visable on the inside of the glove box door.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
Apprentice
Apprentice
Thank you for you help. No my truck has an electric 2speed rear.not a vaccum one. I want to make it go faster then 45 mph. and it has a 4speed i think it is not the original. so i need to look for a Clark 282 or 285 tranny then. and i have 9*20 wheels
Derek,
Before considering another trans, I would first check to see exactly what rear-end ratios you have. A too low gear in high range could possibly be the problem all the long. Try to see if you still have a label on your glove box door for the ratio numbers.
'60-'72 Chev/GMC Fan
GMC 9500 Fan
Detroit Diesel Fan
69chevdump,
There is no question your Eaton two speed rear end is actually shifting into the direct (HI) range!
Stuart
Do find out what the high side ratio is in the rear, and then use this site for calculating speeds. http://www.drivetraindirect.com/t_gear_calculator.htm
If you know what rear you have you can find out what faster gears are available, and if that's all you need to go as fast as you want.
Why don't you want the two speed? Most (if not all) two speed rear axles share a housing with a single speed model, so a single speed center section probably fits in place of your two speed if that's what you want.
You may still need an OD to go as fast as you want, but lets do this one step at a time.
What engine do you have, and does it have a completely round flywheel housing that the transmission bolts to with 12 bolts? or not?
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Apprentice
Apprentice
thanks bill i will look into that tommorrow. i have a 350 gas engine in it.i dont want to get rid of the 2 speed i just want it to go faster then 45 mpph and not be sounding like its going to blow.
Is it shifting to the high side in the rear?
---All pictures---
Grigg,
Not to answer for Derek, but I went thru step by step details on it with him a short while back and he said he could tell it did shift.
This has been a puzzle with a few of us, that hasn't been solved yet. I believe he either has a very low geared high range rear or a 5-Speed trans that won't go into 5th for some reason.
GMC 9500 Fan
Detroit Diesel Fan
I remember that thread, did not realize we were talking about the same truck...
This is the original thread https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/showflat/Main/22851/Number/154993#Post154993
Seems we have already been over this, and he needs to do some checking and trouble shooting before anything else.
Grigg
---All pictures---
Apprentice
Apprentice
Bill, thanks for answering.
Yes that is the truck we are talking about. I have done alot of troubleshooting and for somereason the truck does have a very low rear end but should have a 5 speed but looks like it was switched out for a 4 for some odd reason im checking into the rear gearing soon as i get a chance to get out there.
Hey 69chevdump can you get some good pictures of the transmission for us I am sure I could ID it for you? How many PTO ports dose it have? A swap from a 4spd to a 5spd shouldn't cause this trouble unless the original 5spd was an overdrive and they are rare believe me I have led a long search for an OD.5spd.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
Apprentice
Apprentice
I will try to get some for you. actully i had this truck for sale on here and posted 40 some pics. if you search that you may find a bunch of trans pics. i tryed looking for a badge to see what the gearing was in the rear but my truck has no badging except whats riveted in the drviers door.
