0 members (), 133 guests, and 2 robots.
Topics128,132
Posts1,056,729
Members48,454
#340987 11/24/2007 3:55 PM
Apprentice
Apprentice
Does anyone have any pictures of their homemade rotisserie , I'm looking for ideas.
I want to build one for the cab only for my 38 which two guys can easily lift so its not that heavy really.
thanks
i just used my engine hoister to move mine around...
Another quality post.
Real Trucks Rattle
I built one out of square tubing thats fully adjustable.
Steve
'49 3800
'52 3600
'57 3100
Apprentice
Apprentice
Nice simple design , I like it.
Like the monster casters too.
V
V Offline
macinist.212
If you are interested in a "cab" rotisserie, check this one I built as a first time welding project. It was very simple and worked well. Basically its a cradle on a pipe pivot system. I designed it so it could be bolted to the excisting cab mount holes in the floor. I used 1" tubing and added 1 1/2" pcs where stress points were. Since this photo was taken, wheels were added later.
Good luck and hope this can help you and other bolters.
http://s150.photobucket.com/albums/s107/vickraft/
Vickraft,
I like that cab flipper! I made one for frame with 2 engine stands. Worked fine. 212, maybe will work for you. Pics below. Good luck
Dan
http://rides.webshots.com/photo/2951450480071274430qeOjmO
Here's one I built last spring. It's great to wheel the whole thing outside on the slab in front of the shop to do dirty work and then wheel it back in when I'm done.
Frame Rotisserie being built.
I have the '55 body bolted to the frame while I'm doing the rust repair on the bottom.
Rotisserie in use
The rotisserie is one of those projects what worked out BETTER than I thought it would.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
