1 members (Otto Skorzeny),
145
0
Mod | | | Forums66 Topics128,163 Posts1,056,921 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 33 Apprentice | | Apprentice Joined: Jul 2007 Posts: 33 | Does anyone have any pictures of their homemade rotisserie , I'm looking for ideas. I want to build one for the cab only for my 38 which two guys can easily lift so its not that heavy really. thanks | | | | | Joined: Dec 2002 Posts: 3,445 Moderator - The Electrical Bay | | Moderator - The Electrical Bay Joined: Dec 2002 Posts: 3,445 | i just used my engine hoister to move mine around...
| | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | I built one out of square tubing thats fully adjustable. Photo | | | | | Joined: Jul 2007 Posts: 33 Apprentice | | Apprentice Joined: Jul 2007 Posts: 33 | Nice simple design , I like it. Like the monster casters too. | | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | macinist.212 If you are interested in a "cab" rotisserie, check this one I built as a first time welding project. It was very simple and worked well. Basically its a cradle on a pipe pivot system. I designed it so it could be bolted to the excisting cab mount holes in the floor. I used 1" tubing and added 1 1/2" pcs where stress points were. Since this photo was taken, wheels were added later. Good luck and hope this can help you and other bolters. http://s150.photobucket.com/albums/s107/vickraft/ | | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | Here's one I built last spring. It's great to wheel the whole thing outside on the slab in front of the shop to do dirty work and then wheel it back in when I'm done. Frame Rotisserie being built. I have the '55 body bolted to the frame while I'm doing the rust repair on the bottom. Rotisserie in use The rotisserie is one of those projects what worked out BETTER than I thought it would.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
